Je vous informe que je viens de corriger le bug des photos verticales : vous pouvez désormais aussi bien poster des photos verticales qu'horizontales dans vos galeries
[IMPORTANT] Rapport d'erreurs et améliorations
Mateo
- Petit Baroudeur
joys
Oulala que de bogue avec Firefox là...
erreur 1
mySQL query error: SELECT moderator.mid as is_mod, moderator.allow_warn, m.id, m.name, m.mgroup, m.password,
m.email, m.restrict_post, m.view_sigs, m.view_avs, m.view_pop, m.view_img, m.auto_track,
m.mod_posts, m.language, m.skin, m.new_msg, m.show_popup, m.msg_total, m.time_offset, m.posts, m.joined,
m.last_post,
m.last_visit, m.last_activity, m.dst_in_use, m.view_prefs, m.org_perm_id, m.temp_ban,
m.sub_end, g.*
FROM ipb_members m
LEFT JOIN ipb_groups g ON (g.g_id=m.mgroup)
LEFT JOIN ipb_moderators moderator ON (moderator.member_id=m.id OR moderator.group_id=m.mgroup )
WHERE m.id=113
mySQL error: Lost connection to MySQL server during query
mySQL error code:
Date: Wednesday
04th of October 2006 03:25:13 PM
erreur 2
mySQL query error: SELECT id, member_id, running_time, location FROM ipb_sessions WHERE
id='85a6153a731d4590a892e05b6274dafd' and ip_address='82.127.21.55'
mySQL error: User vrallyl has already more than 'max_user_connections' active connections
mySQL error code:
Date: Wednesday 04th of October 2006 03:32:49 PM
erreur 3
Warning: mysql_connect() [function.mysql-connect]: User vrallyl has already more than 'max_user_connections' active connections in /home.10.2/vrallyl/www/mysql.php on line 5
Warning: mysql_select_db() [function.mysql-select-db]: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) in /home.10.2/vrallyl/www/mysql.php on line 6
Warning: mysql_select_db() [function.mysql-select-db]: A link to the server could not be established in /home.10.2/vrallyl/www/mysql.php on line 6
Warning: mysql_query() [function.mysql-query]: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) in /home.10.2/vrallyl/www/index.php on line 19
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in /home.10.2/vrallyl/www/index.php on line 19
erreur 1
m.last_post,
m.sub_end, g.*
FROM ipb_members m
WHERE m.id=113
mySQL error code:
Date: Wednesday
erreur 2
mySQL error code:
erreur 3
et que ca saute... <_<Justement, filez-le moi ce logo. Format PNG transparent svp (png 24 bits c l'idéal), le GIF n'étant pas géré par la librairie GD à ma connaissance.
T'as qu'à le construire cet aprème vince si t'as le temps, je crois que jimmy a des trucs à faire pour vrally aujourd'hui
Poste-le ici et je m'en occuperai dès que possible.
et un peu moins expéditif ca passe mieux au passage...
donc ok je vais te le faire ton logo en PNG transparant quand j'aurais le temps car je bosse
peut etre a ce soir
Mateo
- Petit Baroudeur
j'ai un problème de page (firefox mozilla)
http://img86.imageshack.us/my.php?image ... treyd8.jpg
C'est en 1024 x 768 pour que ce soit plus lisible.... désolé Vince..
c'est un problème de chez moi ou du serveur?
Mateo
- Petit Baroudeur
je vois que le script est déjà en place pour les photos
bravo !
j'ai fait le logo comme demandé :
http://assos.efrei.fr/vrally4l/Z_OLD/Vi ... y_2007.png
il est en petit (cf l'image) et en cliquant, tu l'aura en grand
merci encore pour ce script, ca rend tres tres bien
vivement que d'autres galeires soient créées !!!
on vous attend tous
PS : je fais une nouvelle version avec l'adresse du site
[EDIT] avec l'adresse (format mini)
bravo !
on vous attend tous
Salut à tous!
Comme vous le savez certainement, je suis une quiche en informatique, mais il y a un truc que je trouverai sympa:
Sous Mozilla, dans la barre d'adresses, il y a un petit logo qui s'affiche en fonction du site (genre eBay, Yahoo...). Je trouve que ce fait vraiment classe par rapport à l'espèce de page blanche par défaut.
ALors si vous trouvez l'idée intéressante, et que l'un d'entre vous se sent l'envie d'apporter cette petite touche...
Merci en tout cas pour tout le super boulot que vous avez déjà fait!
Fab B)
Fab B)
joys
Mateo
- Petit Baroudeur
Bonne idée.
http://www.favicon.com/ http://www.favicon.com/
Toutes les infos sont là-dessus pour le faire. Jimmy tu peux le faire manuellement si tu veux, c'est pas compliqué suffit d'uploader un favicon.ico à la racine du site. Sinon tu peux me l'envoyer et je me débrouillerai.
En tout cas pour dessiner une 4L dans 16px de largeur bon courage ^^. Le logo de l'assos rentrerait pê par contre.
